Make sure you do the Fuse 27 fix!!!
Klavius Morph
Central Washington
This really got me thinking -- my 2011 SCREW stranded me several months ago and I thought it was a dirty MAF sensor, so I pulled it and cleaned it and it's been running fine since. Now I'm wondering if it was a fuse 27 issue.
I pulled the fuse and neither it nor the terminal showed any signs of heat damage, but I'm going to do the fix anyway.
daddycreswell
Lebanon Tennessee
About six months ago I ran into this problem, I swapped the fuse out....and it had been fine until yesterday. Went out to start it and nothing, just cranking..... I do have the relocate kit....just never installed it. Anyway, I looked at the fuse and it was fine, changed the fuel pump relay in the same fuse box....nothing. Do you think the fuse is still the problem? I called around and it looks like $650.00 is going rate to have the fuel pumped changed out in Lebanon Tn. Should I do the relocate kit and see where that leads me? I guess I should, and maybe save me some cash.
Chiefapple
Milwaukee, WI
The fuse may be fine. The socket itself may not be.
daddycreswell
Lebanon Tennessee
I think I'll go home and fix it. Be worth the try instead of dropping $650.00 on the fuel pump. I know these things can go a t any time, but the truck is a 13 with 43k miles. So it's hard to believe that's the culprit.
Chiefapple
Milwaukee, WI
You’re right. It’s hard to believe. Go spend the $650. If that doesn’t work I would guess that they could relocate the fuse for you after.
Klavius Morph
Central Washington
Has anyone in the thread ever had this gremlin pop up while driving & killing the engine, or is it mostly something that shows up when trying to start a cold engine?
daddycreswell
Lebanon Tennessee
Well....I did the relocation this afternoon....no joy. The truck was put on the rollback this afternoon. Wasn't sure it was going to fit......4faceddc5cea23f964cf7cf52d50ad08.jpg
Sent from my SM-G950U using Tapatalk
Chiefapple
Milwaukee, WI
That sucks ass. Still have a warranty hopefully.
Deleted member 17706
Guest
Unfortunately no.....oh well.
My fuel pump went out at 30,000 miles. Fuse 27 appeared to be fine, but I replaced it with the relocation kit just to be safe.
