Low torque at WOT no fault codes
downforce137
In Diana
well if you plan on keeping a ford around, you'll want to look at forscan..
im guessing boost leak, or TPS issues, but until its verified via datalog, its all grasping at straws since there is no code and even the ford dealer is telling you sorry... :shrug:
TwizzleStix
Commivirginia
The amount and level of Ford tuning information rivals the ancient GM and in the case of Ecoboost is way ahead. Check out HPTuners and The Tuning School for some learning. There are no shade-tree “quick fixes” in modern (Ford) electronic engine management. Maybe with the BitchMoanWhine series, but not Ford Ecoboost.
R
Raptor_Kiwi2
Acton Massachusetts
All of the BMW’s I’ve owned have been more reliable than my raptor and cost me less to maintain lol.
Mini update. Watched the misfire counter and on the second pull it registered misfires on cylinder 2, 3 and 5. Swapped coils around and repeated the test. Found cylinder 2 stayed, but misfires moved to cylinder 1 and 6. None of these set a check engine light or registered a misfire fault. Installed new spark plugs and ignition coils and repeated the test, found no misfires present.
downforce137
In Diana
These engines are very sensitive to spark plug gap.. especially when tuned
ToadSmasher2K1
Home Is Where You Make It
Red Kingdom
Is the flexible intake an issue on Gen 2’s? Maybe during heavy acceleration you’re sucking your intake closed…
Look @0:35 in this video
letsgetthisdone
Las Vegas, NV
Our trucks don't do that to the intake.
I love all the arm chair tech's acting like they would even know where to begin with this issue...LMAO
238* coolant will pull timing, and I'm sure MCT is plenty high by that point as well to be reducing timing (the ecu start reducing timing at 100* MCT, 200* coolant). Keep in mind, the tables that do this timing pull are meant to pull timing from the already optimistic borderline/mbt timing tables. So they're not pulling timing to reduce power per se, but more so for the ecu to get ahead of potential knock. Instead of allowing it to knock, then pulling timing, Ford determined how much timing to pull per temperature to keep things happier.
It could be in COT or FOT (catalyst or flange over temp) protection, which reduces enriches AFR without going into PE/OP mode, and if temps keep climbing will reduce target load (close the throttle, less boost, etc). But we need to see data logs :)
