no solution found at my end yet. looked at wheel speed sensors, no codes, all fluids are topped off, no leaks, multiple ecu/tcu resets and relearn cycles, checked transmission fluid levels, drained and filled trans fluid, replaced filter, monitored ABS in forscan, checked 4A/4H functionality...can't remember what else I looked into, and it still does it from time to time.
Still the same trigger for the symptom, normal driving then going WOT in a short burst. Abrupt drop off and you get flung forward like you're gonna eat the dashboard when lifting off gas pedal.
I'm starting to get convinced this is a programming issue. goosetuned e50 and tcm.
