Low oil pressure warning
jef
jef
belgium
I had the sensor installed last week. Problem solved! I went to several places to find parts to install the oilpressure sending unit for the gauge at the same time but they didn't have anything with the same thread as the sensor. So i installed only the sensor. A friend will make the parts for me with the correct thread size to install the oil pressure gauge.
ivo1.cox
Tortona (ITALY)
Hello, I thought you had come, the sensor from the USA, and you've fitted in place of the existing one .. good evening!
Inviato dal mio GT-I9505 utilizzando Tapatalk
jef
jef
belgium
After driving 500 miles, still no warning so it's definitly fixed. Thanks @MTF for the part number and where to find the oil pressure sensor. Couldn't have done it without your help.
Raptorchance
Vail, Colorado
So this is happening to me
Right now. The gauge completely drops to zero and the warning light comes on. I accelerate and it goes back to normal.... in park at idle it will randomly come on and when I rev the engine it goes back to normal opporation.... no leaks anywhere. Hopefully it’s just a sensor or short somewhere in electrical system.
oil level says?
