Love my new lights!
TXCobra
After lots of research and many conversations with John and Sidney @Specialtyperformanceparts - I Decided to go with the following:
2 pairs Fog light upgrade - rigid SRM driving / Spot - these are WAY brighter than stock and even the ford performance “upgrade”. I believe the factory versions are less than 500 lumens and these are over 2300 lumens. Huge improvement
Baja Designs S8 40” light bar spot/driving combo - love this bar because it’s super bright yet lower profile than most.
Rear lights BD S2 Pro - went with the long harness and the reverse trigger so that they always come on in reverse and when I want them on with an upfitter switch.
Can’t say enough good things about the support and guidance from John and Sidney @Specialtyperformanceparts ! They are awesome to work with. Installation was so much easier with the harnesses and instructions they provide. The only thing I want to do is modify the bumper brackets and have them cut down to follow the form of the light bar I selected. These are made to offer multiple mounting points for multiple different lights. I’m just going to trim the brackets down and re-powder coat them. Couldn’t be happier with the outcome.
TXCobra
TXCobra
Got the brackets back and I think it looks much better on this particular light bar. John at @Specialtyperformanceparts has a new bracket coming out soon that is very similar, but I just cut the ones he provided and powder coated them. I also went with satin black instead of the textured ones.
Before and after:
I also got some black oxide bolts and washers to make it match. This stuff won’t matter to most people but I like the detailed differences
Before and after:
I seriously LOVE everything about how your whole setup turned out. Thank you so much for sharing it on here!
Please let us know if you ever need any help with anything else.
Thanks again for allowing us to earn your business!
Sidney @ SPV Parts
(317) 934-6778
[email protected]
TXCobra
TXCobra
I’m not entirely sure but I think it’s very soon if they aren’t available already. Im also not sure exactly which light bars this works for, I do know it’s perfect for the BD S8 that I used. A quick call to John or Sidney will give you the answer.
TXCobra
TXCobra
I went with driving on the outside pair and spot on the inside. Seems to be the most popular choice to balance width and distance out. Give John or Sidney a call, they are super knowledgeable and helpful.
Thanks so much! I am glad you like them!
John
