Sounds good!! Any thoughts on how it will be in conjunction with aftermarket catted down pipes?
All good my man. I'm new here, just got my raptor. But you clearly stated in your first post that you would not buy it for your daily. So your second post is confusing...
That is all.
Sent from my Pixel 3 XL using Tapatalk
I did, but josh is on here answering questions and he’s offering up answers that aren’t what I expected so it has me intrigued. Some acoustical analysis would help seal the deal, but I’m intrigued.
One thing for sure, the 2fg is significantly cheaper than other options.
Don’t tell AWE about the Raptor tax![]()
2019?![]()
THIS IS HOW WE TRUCK. Presenting the AWE FG Exhaust Suite for the Gen 2 Ford Raptor:
The Options
- Proudly engineered, designed, and manufactured in-house, in the USA
- A completely modular, true dual, rear exit performance exhaust configuration
- Precision-engineered H-pipe unlocks a deep, aggressive, drone-free tone
- Handcrafted from 3” U.S.-sourced CNC mandrel-bent .065” wall T304L stainless steel
- Direct bolt-on catback system for factory-like simplicity
- 5” double-walled tips available in diamond black
- Less is more: clean, straight-through design maximizes performance
- Perfect fitment, guaranteed
- AWE No CEL Guarantee
- Lifetime warranty (one year on tip finishes)
2FG Exhaust:
Replacing the factory mid muffler with a 3” precision H-pipe and 3” over-axle tubes, the 2FG Exhaust is engineered to add a distinct, deep tone to the Raptor while uncorking turbo sounds and affording a weight savings of 23.5 lbs over stock.
1FG Exhaust:
Using the same precision-engineered H-pipe from the 2FG configuration, the 1FG Exhaust removes the factory front suitcase resonator and replaces it with two bespoke AWE resonated front sections. This version turns the Raptor’s exhaust route into a true dual configuration, producing an increase in volume and an aggressive, rasp and drone-free soundtrack fit for the Raptor. The AWE 1FG configurations grants a weight savings of 24 lbs over stock.
0FG Exhaust:
The 0FG Exhaust is the combination of 2FG and 1FG configurations, finished off with dual 3” T304L stainless steel tail pipes, and 5” double-walled AWE exhaust tips in a signature diamond black finish.
The result is a unique soundtrack tailored perfectly for the Raptor that comes to life under boost while remaining civil in and out of the cabin at cruising speeds. The AWE 0FG configuration provides a weight savings of 41 lbs total.
Upgrade options:
Equipping 2FG with intentions to add the other sections later? That’s a good thing. We’ve engineered the AWE Exhaust Suite for the Gen2 Raptor as a completely modular configuration that allows you to do just that, at any time. Simply add the desired configuration to your cart, bolt it on, and roar away.
Important fitment notes:
The AWE Exhaust Suite for the Gen2 Raptor is applicable to both SuperCab and SuperCrew models. Adapters for SuperCrew models are included with each AWE 2FG, 1FG, and 0FG Exhaust.
Tip options:
The AWE 0FG Exhaust features 5” double-walled 5” straight-cut tips in a diamond black finish, complete with AWE logo. Each tip is individually adjustable, allowing bumper depth to be set according to personal taste.
What's in the box?
Complete 2FG, 1FG, or 0FG Exhaust, two 5” diamond black tips (if applicable), and all required installation hardware.
Availability:
The AWE FG Exhaust Suite for the Gen 2 Ford Raptor will be available directly through CJ Pony Parts and RAPTORAWE.com.
What’s the matter with you!!!!!?!??
