GEN 2 List your camper/travel trailer info
ryeabs
SCREW
Stock suspension
2019 Grand Design Imagine 2800bh
32ft
~5700 dry
~600 dry (hitch)
double axle
blue ox wdh
Towing around Texas, hills not mountains. Tows well IMO for being at the limits when the trailer is loaded. Only sway issues I've had was bringing it home after purchase. Dialed in the WDH better and loaded the front compartment in the camper (increasing tounge weight). Minor sway will start if speeds get up too high (80+) and big rigs passing. Barely notice the trailer is back there if I keep my highway speeds closer to 65-75. Gas mileage on the other is quite noticeable....
jabroni619
I have a 3500 pound newer travel trailer. Raptor does poorly with it because of squatting. Love my 2019 Raptor, but it’s not a good vehicle for towing
While I agree Raptors aren’t great at towing, 3500lbs should be no problem at all unless your setup is beyond horrible. I pull 3-3.5k regularly and it basically squats just enough to take the rake out.
DarthKickA55
Tennessee
2020 SCREW Raptor
Suspension - 100% stock, (nothing for suspension yet)
Forrest River E-Pro E19FD
19/20'
~2800 Dry ~4000 loaded
~400 lb when loaded properly
Single axle trailer
make/model of weight distribution hitch being used: none (yet) - didn't have a chance before I winterized it
Pulls fine, don't know its back there. It does squat a good bit. Will have a WDH put on in the Spring.
IHAVETWO
NY
HAVE A REESE STRAIGHT LINE HITH.TRIED ALL THE OTHERS.REESE DID THE TRICK.NO SQUAT.DIDNT KNOW TRAILER WAS THERE.TRAILER WAS 6000 LBS PLUS
B
beemerb0y
Los Angeles
2020 SCREW Raptor
19/20'
Single axle trailer
any pros/cons for single axle vs. dual axle ?
2800lbs is very light for that trailer too!
DarthKickA55
Tennessee
Dual is much better. I just found a deal and couldn't pass it up. Will upgrade in the future. Its pretty light and a good "starter" camper for wife, dogs, and I.
jabroni619
also weighs more typically
is it a huge difference in handling? what are the metrics
Its more stable, allows more flexibility on how you position your load to get the proper tongue weight. Redundancy in case of a blow out or flat. I mean you’ll still need to pull over and get it changed ASAP but far less chance of anything more drastic happening.
You have more axles and tires to maintain but they are also handling bit more than half the load vs a single axle with the same cargo.
I have a single and wish I would’ve went dual from the start.
