GEN 2 List your camper/travel trailer info
B
beemerb0y
Los Angeles
I have a 2019 SCAB. I pull a 26’ Coachmen with 1 slide out. Dry weight: #4850
Tongue weight: #490
Loaded weight #5900
WDH
The truck is awesome at pulling the trailer. I’ve had pull trailers for the last 40 years and this is the best tow vehicle I have ever had for this size of trailer. The transmission in Tow mode is great. It holds each gear longer and up shifts are firm and it downshifts for breaking is great.
The SCAB is max towing is only #6000 versus the SCREW is #8000.
The gas mileage is about 9 to 10 on flat highway at 65mph. In the smoking mountains I was lucky to get 8mph but who cares you are pulling your trailer with a Raptor. I get a lot of smiles and thumbs up.
Hope this helps
this post is a relief :)
Ski4Ever
Denver, CO
Ok, did that, someone explain to an "old guy" what that even is?
It's the difference between me typing Zeusmotorworks, and @Zeusmotorworks. Notice how the second one is a link? It will (should) most likely send you an email that someone (me) has tagged you in a post, so you'll get a notification and know that someone is trying to get your attention.
zx14teryx
I have a 2017 Raptor SCREW with the HD +3 Deavers, and 37" Toyo M/T Open Country tires. I use a WDH and sway control bar along with the electronic trailer braking system. I tow a 30ft long Puma Canyon Cat with dual axles that is 6200lb dry and 7700lb loaded. Around 800lb tongue weight. I also have the MPT 91 Performance Tow tune in use when towing. Does great! You can see a little bit of squat.
FYI - I also have a 170 thermostat installed and pulling on flat road and inclines only saw a max temp of 195. Pulling on flat, it stayed right around 185 which is when the fan is programmed to kick on. I noticed the Performance Tow tune doesnt utilize the turbos much unless you really bury your foot in it.
How does it ride unloaded?
