MarkT
- Joined
- Mar 4, 2010
- Posts
- 1,202
- Reaction score
- 26
I am assuming that your impression is that on the stock vehicle the RCH is considerably below the COG...
I did not take exact measurements as it is not easy and it is very time consuming on a production vehicle. So I don't have the exact numbers you would get if you took the time to carefully measure and plot the suspension layout before and after the lift. My assumption, based solely on "eyeball engineering", my experience, and B's driving feedback is that the RCH was raised more than the CoG height was raised when he lifted the front of his Raptor.
Having the RCH move a lot more than the CoG height would be unusual. But one unusual behavior on the Raptor is how the front wheels gain quite a bit of negative camber when you jack it up. (the tops of the tires lean in) Most cars and trucks gain positive camber when raised. This indicates that the Instant Center (IC) of the Raptor front a-arm design is in an unusual place for a production vehicle. And this specific and unusual placement of the IC at ride height would result in unusual RCH behavior in my experience. I'm not an "expert" as Dan said but I've never owned or worked on a stock "street" vehicle that was set up this way.
Could B be experiencing the seemingly counter-intuitive handling change like stating lifting the front feels like it resulted in less body roll? In my experience, yes. And the other observations B made are consistent with the RCH being raised more than the CoG height... like less dive under braking.
YMMV.:thumpsup2:
