I'm in the Southlake area - any good shops close around? I'm focused on a ~1.5" or front level, not fully decided between new springs or perch, but inclined to the perch solution. I'm not planning larger tires or super wide stance. The lift is primarily for aesthetics.
I was going to throw a bingo card here, but n00b user and all.
If it’s just for aesthetics there are far better ways to spend your money, especially if you decide later on that you want to do... IDK, Fox Racing Shocks, etc. I think -others jump in here- you may need to recalibrate the ride height for this (FORSCAN). You’re adding strain to the front drivetrain here and blinding pretty much every oncoming car with your now way out of spec headlight alignment.
I’d bank that money, if you decide on suspension mods with a non-trivial purpose, the supporting vendors here will steer you in the right direction.
