LED Illuminated Tailgate Ford Oval
infinitereality
SLC IR/8
Louisiana
I found this a few months ago but never decided to go forward with it. I Googled some pictures of it installed back then and here recently prior to ordering but surprisingly no one has installed one of these on a F-150 or Raptor, least that have posted pictures of it. Last weekend I decided to give it a shot, heck for $25 shipped it was worth a shot.
Red LED Lo Glow Light Assessory for Your 9" Ford Emblem Badge | eBay
I had previously painted my bezel same gray color as my stock bumper and the emblem just black and added my own gloss white vinyl emblem over it. Wasn't easy to get back apart, I had epoxied it together but with some heat from the heat gun I was able to get it back apart.
You do have to modify the stock bezel and oval to fit this illuminated oval. You have to cut it down so the Lo-Glow will fit on top of it and cut down the tabs on the stock oval so it will fit flush. No big deal, used my Dremel with a cutoff wheel to get stuff level.
I wired it up with my driver's side running light wires for the stock tail light. The purple wire is positive and the black wire is negative. Both have a stripe on them, but I don't remember what color the stripe is. Just test with multimeter to verify. I stripped them back and soldered a pair of new wires to them, wrapped in electrical tape and put some heat shrink on them. Fed it under the bumper, then with the wires that go to the tailgate for the reverse camera. Heat shrinked it to keep everything safe and fed it back through where the emblem holes are at. Soldered it to the wires from the Lo-Glow board, wrapped with electrical tape and heat shrinked them.
After testing everything to verify it works, I just heated it up with the heat gun since it's cold outside and make sure I had good adhesion. Pictures that follow should make my confusion thread a lot easier to follow, I tried to take as many as possible but forgot to take some where I tied into the driver's side tail light.
I'm fairly pleased with it. I have yet to see at night and will follow up with some night time pictures, but seems to disperse the light decently.... it could have done a better job at dispersing the light IMO but honestly looks better than I anticipated it would. I thought I'd notice the increase between bezel and oval with the Lo-Glow board, but I really don't. It's not even noticeable, which is surprising.
infinitereality
infinitereality
SLC IR/8
Louisiana
I was surprised I couldn't find any install pics on a F150 even. Something different at least. I've been wanting to illuminate the grill letters since I've owned the truck. Even have an idea how to do it and bought materials, just have yet to get the balls to cut the grill.
AbnMP13, I didn't bother posting the instructions because they aren't accurate, least for our trucks. Mine didn't even come with installation kit or with printed instructions. I wouldn't have used the connectors anyway, best and only way is to solder and heat shrink in my book. Their instructions don't show a bezel and how you have to modify it in order to fit the product. I figured it was important to let others know what was involved if they wanted to order one.
Yukon Joe
Trafford, PA
Looks cool.
Does it mess with the rear view camera at all? Or show up in the video?
You sir got some bright license plate lights.
Thank You for your donations to Avery. We hit our goal!
Yukon Joe
Snoball 3
Delta Lead
www.runraptorrun.com
infinitereality
infinitereality
SLC IR/8
Louisiana
Joe you have a good point. When I back up last night, I didn't think about it affecting reverse camera but by same token I definitely didn't notice any difference. I meant to take a picture of it for the LED thread on how well the reverse lights work. So I think there is no interference with the reverse camera. :)
They are definitely bright, but keep in mind the camera skews the brightness with my phone. Been running same bulbs I've recommend in my LED thread. :)
Just updated the pictures so they'd show up automatically and rotated properly. I'll get some legit ones with the good camera this weekend.
Humvee21
To the human eye, red light has no effect on night vision. I'm not sure if this is the same for cameras but that could be why the camera had no difference. I wonder if it'd be different with a different color light
