King Shock’s new bolt-on, OEM performance kit for the Ford, Raptor delivers increases in wheel travel, damping force and overall performance when compared to the stock suspension. King’s engineers have spent countless hours tuning the shock valving to enhance off-road performance without compromising the Raptor’s on-road manners.
The front monotube, 3-inch diameter coilover with King’s Wide Range Compression Adjuster has over twice the piston surface area to provide greater damping control and 20 precise clicks of compression adjustment to fine tune the ride for any type of terrain. The nitrogen charged remote reservoirs help to cool the shock fluid and prevent shock fading when you need performance most.
In the rear, the kit comes with a race proven 3-inch diameter, triple bypass shock with nitrogen charged, “Piggyback” remote reservoir. The bypass tubes adjust both compression and rebound damping to provide total control throughout the travel range.
Like all King shocks, they are made in the USA to strict precision tolerances using the finest billet materials available and are serviceable with simple hand tools. When the time comes, you can rebuild your King shocks to factory fresh condition for many more years of reliable service. If you want uncompromising performance from your Raptor, nothing else provides the durability or control that King does. When you ride on Kings you’ll know, there really is a difference. Go to
King Off-Road Racing Shocks: Coil Overs, Bypass, OEM, UTV, Air Shocks, Bump Stops, Springs, Replacment Parts, Tools, Springs « King Off-Road Racing Shocks : kingshocks.com or call 714-530-8701 for more information.
