Keyless entry stopped working
TexasAggie94
Harker Heights, TX
Correct. For some reason the passenger side is the one that stops functioning when battery voltage drops.
Even if the battery is fully recharged, a battery monitoring system reset will often need to be performed so the BCM knows the battery is no longer discharged.
Sir, wanted to follow up with you and this thread. I can confirm that after a long drive today (45 minutes), the voltage reading dropped from 14.5 to 14.0V. After another 45 minutes of driving, I tried the passenger side door handle and it worked without issue. Problem solved. Thanks for saving me a trip to the dealership and some unnecessary trouble shooting! Love this forum!!!
Viking84
Viking84
Norway
Just to update, my keyless entry systems are all working again too, just a few long-ish drives needed to get it running again :) Hopefully others will find this thread helpful
D11gnccer
Columbus Ohio
I wish I had read this prior to letting the dealer tear into my truck. “All is fine, we returned the body control module to as built setting.” I picked it up today and the passenger side was still not operational. “Looks like we will need to replace the BCM. Bring it in tomorrow.” They are transferring in a BCM from another dealer.
Viking84
Viking84
Norway
Ouf. That is the road I would have gone down as I rarely have the patience to wait and see if things fix themselves. Thankfully it is all working nicely again now - some times it will cut out if I have been in and out of the truck a lot, which is understandable as I'm barely driving anywhere now that we are all back at the home office.
