LFtrip
supercab or crewcab?
Oh sorry, screw (4 door).
pry the little cover off the seatbelt bolt. then its a t50 torx and then the panel is held on by metal clips. just pull outward. be careful because the clips can be tight sometimes and cause stress to the plastic causing white lines if you pull to hard or too quickly.
---------- Post added at 04:13 PM ---------- Previous post was at 04:12 PM ----------
i forgot, you should remove both door sill trims too. thise just come off by pulling up on them. but again, be careful of stressing the plastic. sometimes the rubber seal comes up too. not an issue. just put i back down when you get them off.
---------- Post added at 04:17 PM ---------- Previous post was at 04:13 PM ----------
no. wait. one more bolt. it is a 7mm behind the little plastic cover that says "airbag"
sorry, i kept forgetting parts. but i remembered them all finally.
do you want 1 or 2 woofers? i make boxes for both setups.
