I've Got a Few Random Questions
Winchester30
WI
Mine has been to dealer already to have that rear seat fixed.
Dealer replaced rear seat latch assembly.
My dog likes riding back there except when the seat kept hitting him!
MDJAK
MDJAK
NY
You guys are sullying your own reputations for being nasty tough guys. Lol. Jk.
Really appreciate all the replies.
So nothing ventured nothing gained. I’ll ask another one.
August 10 we leave in the Raptor to Utah, a week in and around Moab, antelope canyon tour in AZ, and then head up to the Assault.
Would you drop the 350-450 for a pro eagle jack just in case?
I have a tow strap. Should I also spring for a Bubba strap?
I’m not planning any very difficult trails, just the usual.
Nick@Apollo-Optics
But I digress. When I first joined here, this place could be a bit brutal. I got used to it quickly and people have actually been very helpful to me. I've gotten many informative replies to my sometimes dumb questions. So I may as well press my luck.
In no particular order: (Yes, I know, if I RTFM, I could probably find the answers, or maybe not, but you guys are so much clearer for me.)
1. Are the daytime running lights the same as when the headlights are on? I saw a '17 or '18 behind me in daylight on the highway and the headlights did not seem as bright as my '19. Is that because they DRL are dimmer?
The DRLs are slightly dimmer. I'd venture to say 80% brightness on DRL vs 100% on normal use.
2. A FORSCAN question or two. Yes, I know there's a 50,000 page thread on it. It's overwhelming to a simpleton like me.
Bambi mode. What exactly is it? Does it turn off the DRL and turn on the yellow/orange trim light around the headlights? If so, I want it.
Bambi mode only applies to the regular F-150s with OEM headlights. It allows the high beams and the fog lights to remain on at the same time.
2. Another FORSCAN question. I bought the piece that goes in the OBD port. I've yet to use it. Why? Aside from being a partial dope, I'm afraid to f something up. With all the videos I've watched, all the posts I've read, I haven't found one that clearly and easily explains how to back up your original settings before taking the dive.
Personally, I use the wired cable to connect for Forscan. I didn't see the need for BT when the wired module works fine. Don't be scared. Read the manuals thoroughly to the point where you understand everything. Watch some videos if needed. Save every single module before you change anything. Then, follow the instructions and make one change at a time. You can do it!
3. When you brake hard, does your rear seat, if it's in the up position, come down? Only the side that's larger on mine does. The smaller one requires pulling the strap to lower.
Haven't had this issue on our 2018.
4. What the heck is the BiltRite thing that releases and locks the seat back for? is there that much space back there to store stuff?
It make it a heck of a lot easier to lower the back of the seat on the driver's side rear seat latch. There is some space back there, not a ton. If you have a truck with the OEM sub, there's really not a lot of space. But there is room for tow straps and other smaller, flexible items.
5. This one is a bit more important to me so give it your best shot. Now that Cobb is offering a tune for the '19, I haven't seen that many write-ups on it, but I see many on other tunes.
So, which is the best tune for the '19? And will it give a lot more power without other mods?
We carry quite a few options, but honestly, we lean towards COBB each time. The multiple years of R&D behind them in multiple climates and elevations make them safe, reliable, and powerful. They are as good as you're going to get for a canned tune. That said, the lack of TCM support, for now, is the system's shortcoming. However, COBB is actively working on it and it is priority 1 for COBB's Ford team now that Stage 2 ECU support for the 2019 trucks is available.
If you want more or want a custom tune, there is a network of COBB Protuners available for both e-tunes and actual dyno tunes if you want to explore custom tuning.
Last and probably least, what is that little hoop strap attached to the side of the seat near the seat belt buckle for?
Honestly, I never figured this one out. I always thought it was some kind of "stop" to keep it from going too far in a certain direction, but that's as far as I got.
Thanks again.
Put my answers in red below each of your questions. Hope this helps!
I probably wouldn’t be the one springing for the jack just yet and I think the strap is probably enough for what you have planned. Really, you’re just buying Murphy insurance. You buy the basic recovery equipment and because you have it, you won’t get to use it.
What you might consider is a tire plug kit and a decent air pump, because the inexpensive green slime air compressor kit that works on car tires, is going to probably take the better part of an hour to fill a 35” KO2. Maybe a come along/hand winch, possibly an anchor, like the pull pal, and some of the fiber / plastic traction pads.
I’ve never used the pull pal specifically, but I did assist someone who was hand winching his stuck truck using a long solid steel rod he was beating into the earth. It took a while, but we got it un-stuck.
HTH
dewalt
Maasdam 3/4 Ton Rope Puller good hand winch
probably need a snatch block
If you are getting a rope you need hard and soft shackles
Look at a 110 volt compressor rated under dash rating
valve cores and caps
dewalt makes a good cordless compressor, with 12 volt backup
but you need a good battery for big tire
MDJAK
MDJAK
NY
Which portable compressor do you recommend I have a high quality tire plug kit
I ordered / used this one at the beach:
https://www.amazon.com/gp/product/B005ASY23I/?tag=fordraptorforum-20
If you’re planning on playing in sand and considering airing down, I would suggest this or something like them to make this process quicker and easier
https://www.amazon.com/gp/product/B01M0L7JS2/?tag=fordraptorforum-20
The air up from ~20 PSI was about 5 minutes per tire to street pressures. The gauge on the compressor is pretty accurate when it’s not vibrating its tail off. Pro-tip: this compressor gets really, really hot. Best to not pick it up or touch it in the wrong places.
HTH !
