francois perrot
hi everybody,
I have had a spongy break pedal and took my 2013 raptor to the mechanical. Brake fluid, booster, and master cylinder have been changed.
Apparently the mech said that the problem was still there, so he changed the ABS pump.
Since then, the down hill button led is blinking, DTC dash board sign is lit orange fixed, if I try to engage off road when car is stopped, a message says that I should be below 5 kph, same if I want to go in 4x4 low, the inclinometer is showing 45 deg in both axe when car is flat in the carpark, maybe other stuff I havent see. The mech now says that I need to bring the car to ford because a software need to be downloaded in the ABS pump? does any one knows about that?
thanks in advance.
Francois
thanks in advance.
Francois
