flynford
What's up raptor enthusiasts! So I just Had my first "major" problem with my truck after 10 years.. Yesterday my battery Warning Light Came on. I tried replacing the battery hoping that would solve the issue, didn't help. In the mean time It also started making this weird whining noise whenever the battery light would pop up. I put the old battery back in bc I didn't want to ruin a brand new Optima Red Top (hopefully the new battery is still fine). Started to smell a weird burning electrical wire type smell as well. When I opened the hood I noticed pine cones stashed up in my engine compartment maybe from squirrels or other rodents. I have found pine cones under the hood before so there is a chance its unrelated but they could be chewing up the wires?
I know some will maybe say alternator and it could be, but I have a feeling its not. A week or two previously I did have a dead battery assuming it was my stereo and running lights were on while truck was off. (battery died pretty quickly, hence why I thought I needed a new battery), the alternator had charged the dead battery back up. maybe that was its last leg idk...
Any advice would be greatly appreciated?
I have an apt. to take it in to Capital Ford in Carson City but still is a lil ways out, feb 2nd.
This just started happening yesterday and I'm not driving the truck bc I don't want to damage it any further. Probably going to have to tow it to the dealership. Maybe put on 4-8 miles in total with the problems that started happening just to get home.
Do you happen to have a volt meter handy? You don't need a fancy/expensive one and if you don't have one it would highly suggest to have one in the tool box anyway. If so, check the voltage while engine-off, and then again when the engine is running. If the alternator is working it should bump the voltage to 13.5 to 15.2 range. If there is no change then it's gone. If you get little change then it is dying a slow death.
One thing to note, especially for folks who install aftermarket gadgets/gear that these Fords don't have much for switched hot circuits. Even with no extra gear installed, the battery won't stay charged well enough to start the truck after a couple weeks. If the battery is in good condition, you can still hear the weaker tone when cranking. My older Fords can be parked for months and not observe a degradation as compared to the newer Fords. This is because of the many items on the truck are powered-on with the engine-off-key-off. I decided to install a Switch Pro myself and found this out on my own and hunting down a switched hot took some time. Also, be sure that there are fuses installed for the gadgets/gear you have had installed. For the very reason like you stated, things happen, in this case critters maybe chewing on wires and if there aren't fuses there, it could cause intermittent shorts while you're driving around town to where you maybe frying wires for while until its gone. Or, later things get pinched and severe shorts develop. Depending on what gear you installed you may not know until you try it again.
