This is exactly how many ***/Audi cars roll.This photo is of a Chevrolet 2500HD Diesel pickup coolant stack. The small radiator at the bottom is the trans cooler. Front to rear is the air-conditioning condenser, intercooler and radiator. Notice that the intercooler on the 6.6L diesel is huge compared to the one on the Raptor.
What all of you fail to understand is that air flows through the intercooler. Very well I might add. It isn't 'blocking' anything. The air temp differential from ambient to after the intercooler won't be more than 5 degrees or so. *** cars sandwich the AC/Intercooler/Radiator in that order with the radiator being last. This is from the factory. Now, you may ask yourself why that order? Well, I can theorize as I've owned one and replaced the IC on it as well with a stouter unit. AC condensers get hot, in fact when it is hot and you turn the ac on, you feel the decrease in power as now the IC is getting super heated air.
Secondly, there are aftermarket companies that make aftermarket intercoolers that are relocated to the bottom of the vehicle - removing the IC from in between the AC and radiator. The units are smaller but are a true FMIC. Guess what? They do not perform nearly as well as a good aftermarket IC in the stock sandwiched location.
In order to know why Ford did what they did with the OEM setup we have to understand their goals. IMO the stock IC is the weakest link in the cooling system, bar none. Not only is the unit a pile of shit to begin with but they place it right behind where the license plate is supposed to go. Fans on an IC? That is a first for me, never seen it before. Typically fans are not needed on an IC because when moving, an IC needs to get airflow - almost impossible when you block 80% of the opening to get the air you need.
I know everyone on the internet is a PHD and all that but what I can say is that I have done extensive heat exchange testing - including studying the effects of sandwiching them, the very subject we are discussing here. Anyway, get a blower or a hairdryer and blow it though a radiator or intercooler if you have one laying around, you will see it's almost like nothing is there in terms of affecting the airflow.
no F'n way would you stack rads like that or you're almost guaranteed to have an issue
Do any of the *** heat exchanger stacks have a tranny cooler second?
No. However, I have seen zero difference in tranny temps from stock IC to relocated IC - I have the temp displayed via ForScan on my cluster.
I'd tell you you're wrong, but you're clearly thick.
I don't tow so no. Normal conditions so far - it does get rather hot here in the summers though.interesting. Have you taken it into the dunes or done towing while watching the temp or was this just under normal conditions?
Sorry my bad... and no, I'm not arguing that sandwiching is better than not, all things equal. What I am arguing is a big FMIC in front of the rad and transcooler is FAR more beneficial than having a smaller IC in the OEM location and that the FMIC is much less detrimental to radiator cooling than you think. I have a 170 thermostat in my truck, even in the dead of summer I don't see over 200 degrees, ever. Usually hovers around 185ish.You realize you’re quoting a comment in reference to my blown vette, not a raptor right? In that scenario- no I’m not wrong- no F’n grill bud. Only limited spots to gain access to cold air.
whatever- you’re basically arguing sandwiching these cooling condensers is a better option than not, and it makes zero sense
