iphone mount
BlueSVT
San Dimas, CA
LD50
I did the Pro Clip as well, only I got the universal mount with the pass through connector in it. For now I have a cable running from the USB port, under the AUX switch panel and up behind the dash. I was able to snake the end of it out through the seam in the dash just to the right of where the mount is. After I get the necessary USB connectors I'll pull it up inside the dash and hook it into the second USB input on the nav.
maxvdub62
I did the proclip mount as well as the pass through connector. I also got a short sync cable from Radtech so there is no slack and looks cleaner.
Humvee21
^ How do you have a cubby hole on your driver's side?
And what's the thing above it?
dataustin
Max, that looks clean! A couple of questions....
How does the iPhone mount to the dash?
What is the connector on the bottom of the phone?
How are you powering your iPad?
Thanks
maxvdub62
It's a combination of double sided tape and it snaps on, it's from proclip usa.
It's a pass through connection from proclip usa
It does not have any connections going to it as the ipad has an amazing battery life, but I could connect a cable to it if I wanted. Plus I would never want to leave it in the vehicle. That's just asking for it to get stolen.
