Infinite Reality's LED Thread
NickPic83
Rockland County NY
r u sure its the LEDs? i would go back to all the regular bulbs and then see if that actually fixes it. i have never seen an led bulb blow fuses, led light bars and cubes yes, led bulbs no.... usually they will just start flickering or stop working all together but anything is possibly. also make sure none of the pins on the led bulbs moved and are close to each other to the point where going over a bump could create a dead short
McDowell
Oklahoma
I installed all these LED's a few months back and now, all of a sudden, they are starting to blow my fuse. The rear license plate lights, tail lights, and rear side markers. I got Ford to fix them once but it just blew out again a week later. Anyone experience this before and have any advice? I really don't want to be driving at night with no tail lights...
Mine did this because a bulb was loose and was causing it to blow fuse it would fall in and out when lights were supposed to be on. Make sure evrything is tight
Sent from your girlfriends closet
Aventador22
Turns out it was the license plate ones causing the issue. I'm going to order some new ones but in the mean time I have my factory ones on...what a change in output...
Thanks for the help!
McDowell
Oklahoma
That's the ones that were doing it to me too
JRaptor11
Maryland
Gotta find another set for my cargo lights. The ones I had in there broke and all that was still in the socket was the pins.
apeezie289
Apologies if this has been asked already. For the flood light in the back seat, what led light are y'all using? The OP instructions wasn't correct for
My '13
infinitereality
infinitereality
SLC IR/8
Louisiana
As far as sealing puddle lights, I just used some 5min epoxy, almost 18 months later and still no issues.
For the rear interior light, I listed it for a Scab.. Assuming you have a Screw, I belive someone stated what size it is. If not I'm sure someone will chime in to help ya
