Infinite Reality's LED Thread
infinitereality
infinitereality
SLC IR/8
Louisiana
Samsung on the way here...how does one get the puddle lights apart to replace the bulbs with LEDs
And how do I get the dome cover off? I tied and felt like the headliner was going to pull down?
Puddle you will have to get lense off with dremel is what I did.
Dome cover comes off, there's 2 tabs on the back with 1 on the front. If you pull it slightly down from headliner you'll see the tabs. Put a flathead inside it and it should pop right off, the go to next side.
Fred
Richmond, VA
Thanks Nick...I think I can handle that on the Dome...I did not see anything regarding the puddle lense removal on your build thread...
I guess a Drexel tool needs to be ordered? What attachment do I use?
---------- Post added at 09:55 PM ---------- Previous post was at 09:52 PM ----------
What attachment did you use to get the cover off? How did you reveal the cover back on and ensure it is water tight...
Thanks for your patience with me on this
infinitereality
infinitereality
SLC IR/8
Louisiana
I just used the dremel slightly around the perimeter of the lense, just enough to eat the glue. Just go slowly. There are other options to getting it off without a Dremel too, but for the life of me I can't remember them... Razor blade?
Fred
Richmond, VA
Thanks, will give it a try...
NickPic83
Rockland County NY
I used an oven at 250° for a few minutes then with gloves used a razor knife and scored it all the way around. Then with a small screw driver i gently pried on the lens all the way around. Just take ur time. Its not too bad.
Sent from my DROID RAZR using Tapatalk 2
Fred
Richmond, VA
Hey Thanks Nick...I will try the oven...might taste better than some of the wife's cooking...
I got the map lights in the mail today...look great
I also got the below in the mail as well...What the hell are these light for?
infinitereality
infinitereality
SLC IR/8
Louisiana
My map lights should be in today, curious on how well they'll match new cargo...
Those appear to be for your vanity mirror maybe?
