Improve throttle response?
GEN3LV
Las Vegas
Yea just kidding, but I wish I knew about it when I first got her. I would have done it.
I don't think so if you already have a tune. Its great if your not running a tune due to warranty issues, that's why I use it you just turn it off and they will never know its in there.
Floyd91
First impressions after installing my S&B intake is that it's definitely snappier on the throttle. I've only driven it for about 30 minutes but it definitely feels more responsive.
Ruger
Northern Nevada
MTF is right, the mono-blade on the raptor doesn't work too well. I just put on the ford twin 65mm and there is a fairly noticeable difference. That is a butt dyno measurement. I also just installed the guage cluster JDM is offering and the 0-60 guage is quite cool. Making 6300lbs go from 0-60 in under 6 seconds is quite entertaining!
As for the tuner questions I would say the 5 star is most aggressive(I had it). Since I have been sc for a while, it seems like SVC has gotten a lot of positive reviews on here. When I did it(2 years ago) 5 star was the overall favorite on here. Now maybe SVC based on what I am seeing. I am guessing that tune is a little more driveable everyday, than the 5 star.
Can you please elaborate on that throttle body?
And does anyone know the diameter of the factory throttle body for the 6.2L?
MTF
Celebration, Florida
I believe the stock TB is a single 60 mm and the BBK is a single 68 mm.
The TB's for superchargers are twin blades and single oval blades.
Twin blades start around 60 mm to 72 mm for each blade.
Mono ovals are 150 mm to 200 mm
Ruger
Northern Nevada
85mm throttle bore
Fits 2010-2014 Ford F- Series Truck 6.2L - Ford Raptor, Ford F250 6.2L, XLT, Lariat, FX2, FX4 and Platinum edition
This BBK 85mm F-150 throttle body will deliver more horsepower and works with both OEM air intakes and aftermarket cold air intakes
Question: How can an 85mm TB be compatible with factory and aftermarket intake components designed for the factory 60mm TB?
