BramageDained
- Joined
- Aug 4, 2012
- Posts
- 761
- Reaction score
- 449
Still need to make the mount for behind the grill tomorrow as last bit of snoball prep, but, that should be pretty straightforward.
Amber rear+blue for front for the snow.
Amber is mounted with custom adjustable and removable adhesive mounts that look suspiciously like the extra GoPro mounts I had laying around.
I doubt someone would swipe it, but, if they do, I'm only out $30 in materials and some time. Then I'd just make a proper one like the smaller blue lights with another revision.
Temporary mountable since I'm not sure enough on where to mount it to drill holes in my truck.
I have enough LEDs left to make a few more, but, my ideas for the next version require some tools I do not currently have access to.
For now, anyway, the rear and front, center are going to be tied to the same upfitter switch. I have another driver so they could be separate, but, this was an afterthought and I cannot get more heat sink in time to mount another driver.
Switch 1 will run the center/rear
Switch 2 will run the outer 4 on the front.
I could run it all off of one switch since it's ~21A, but, I choose not to for now.
