The top plugs are relatively very easy and are all done, I'm currently working on the passenger side ones and looks like the very front one will be a tight fit with the shock bucket in the way and I have the inner fenders off too. Will post pics later of this. FYI, another member mentioned using two 5/8's sockets, one with the rubber insert and one without, I've been following this procedure, use the rubber insert for removal of the plugs, but I just use the rubber insert socket to start the new plug and then switch to a regular long socket for tightening the spark plugs, works like a charm as the spark plug holes are very deep and you don't want the socket getting stuck in there and have to loosen your new plug to retrieve.
