GEN 2 IDJMTOY 10" LED Install
wrek
So what do you think of the quality? What is the light output? It doesn't provide much information on the amazon webpage on these lights.
M
MKomertz
It's phenomenal. You can change the angle pretty easy but their 100w light and light things real nice. Definitely a huge difference
wrek
I installed over the weekend. Were you able to angle yours to the front? Mine are at 45 degrees to the side. I have tried and tried but the way the brackets work, hard to get it anywhere near the front.
motorsports_3
Looks nice, different than the 3 led lights, though I think I still like the 3 lights more as they seem more versatile.
M
MKomertz
Grayden installed for me so he could tell you more on how to do it.
Grayden
If I recall correctly the lights were fully adjustable horizontally and vertically. do you have any pics of the install so I can see how they are mounted.
wrek
Pics attached.
Grayden
Pics attached.
I would say that it looks like MKOMERTZ and I decided to mount the lights higher on his. The upper hole on the bumper that has the small 45* support bracket is the hole we used. You can see how low yours are if you compare it to his pictures. Let me know if that helps. Also make sure you loosen the nuts enough, I think the mounting area is knurled to help lock them in place while tightened .
wrek
I thought about doing that. that was going to be my next thing to try. I was following the instructions and ended up with what I have.
Grayden
HAHA, F the instructions man, LOL good luck that should give you more adjustment.
