Icon Multi-Rate Rear Leaf Spring Kit
Wojciech Gierczynski
Illinois
Are people experiencing much sag at Option 1 with 500# or so in the back?
This weight should put you back to stock height in the back. The other day I had aprox. 480lbs in the back between ATV and ramps and didnt noticed much drop on Option 1. I would say it went down maybe 1/2 to 3/4 inch. Back was still higher then front since after Icons Option 1 installed it went up about 1.5". Thats with Eibach springs in front on 2019 with Live Valves. Thats how truck sits empty.
OffroadAlliance.com
Boston, MA
We have Icon rear leaf springs in stock! They might be backordered with Icon until mid August, but we've got a few sets left and ready to ship.
Give us a call or check us out online.
Phone ---->>>> 888-466-8991
Web ---->>>> OFFROADALLIANCE.COM
Mariners Fan
Spokane, WA
Has anyone done the Icon hydraulic bump stop kit with these and not just the pads? I feel like I'm falling down a "rabbit hole" - I'll be mostly pavement driving but it'd sure be nice to have the performance there on the rare occasions I do OR. Or is the hyd. setup just overkill?
Slow6
AK
What’s Overkill?
You could get by with the extensions they offer for the factory bump stops, but if you think there is any chance you might upgrade to hydraulic bumps do yourself a favor and install the bump plates when you do springs so you don’t have to later.
WRCRaptor
Great Lakes
I installed Icons set at option 3 this weekend and wow is it high without anything in the back almost 4"! If they sag a bit that would be great but I think a set of RPG drop shackles are needed. I went option 3 because about 6-10 times are year I have about 700lb to carry and on my Gen1 the Deavers +3 HD they sagged a ton after one year.
So this time I wanted to try Icon and set to option 3 the ride is firm like a euro car over expansion joint and wash board. The rear does not skip around at all and most of the axle hop is gone under acceleration. Just like my Gen1 rear springs made a huge difference in a positive way loaded or not.
I do have Eibachs up front and they are also a great mod. I liked the Gen2 in stock form for daily driving although it was a bit unsettled in the rear on wash board and small bumps, tire air pressure made a big difference. I just like a bit firmer ride on the street and increased sag resistance when loaded. These springs do give you more confidence and control off road for sure. I think if you are not carrying lots of weight that Icon option 2 and Eibachs would be perfect.
I have a Live valve 2019 and I have not noticed any issues with the shocks and the higher ride height.
The rear Icons also remove about 80% of the Axle hop under acceleration.
I have not seen any posts about option 3 so I hope that helps and if you have gone option 3 post you experiences.
Mariners Fan
Spokane, WA
Did you do the bump stop pads or hydraulic bump stop kit?
