Icon Multi-Rate Rear Leaf Spring Kit
Ckhris
Will the icons stage 1 carry more of a load over stock? When I put 12 bags of deer corn in the bed it really drops the back.
NEOGARAGE
North Royalton, Ohio
Yes, they increase the amount of leafs in the pack (3 up to 8), so you can carry more weight before it starts to squat again. Spring rate is increased because of this but being a progressive spring rate, on road ride quality isn't affected, and even improved. The back end feels much less jittery over washboard roads. I would still not recommend going over the manufacturers rating, but upgraded leafs help a ton. This will lift your truck 1" off the bat though. Deaver makes an upgrade that will not lift your truck, but we've found the Icons to be much better for people and the adjustability is nice if your uses change down the road.
https://www.neo-garage.com/collections/2017-ford-raptor/products/icon-rxt-leaf-springs
We run option 2 on our shop truck and regularly tow a 7800lb Tacoma/trailer/gear to events and it's awesome.
Ckhris
Thanks
NEOGARAGE
Will the icon leafs work with stock shackles?
Yes they will!
upgraded shackles from Camburg aren't a bad idea for extra strength and less binding, but the stock ones work just fine.
shoot us a message if you’re interested and would like to order. We’ve got probably the best pricing on these :cool:
Cory s
Orlando fl
Yes they will!
thanks brother i already have a set just need to install! Not impressed with the finish of the springs. They look like hammered dog shit!
