Icon Multi-Rate Rear Leaf Spring Kit
0-60 freak
How much trimming required for the 37’s? Wheel offset?
So I've only trimmed the bare minimums to clear it right now, when the spring settle down to their final resting position I'm sure I will have to trim probably an inch more oh, but I can always trim more I can't add back that's my mentality881520d9eb11a932c1712bd4199355bf.jpg14bcbc911e184536bd8df3576b1c3c49.jpg
Sent from my SM-N950U using Tapatalk
Slow6
AK
I’ll keep watching an see how much more trimming is required...
Thanks
xgardx
CLE OH
Is this while just sitting on flat ground and it runs that much, or is that with any amount of compression on the front corners?
0-60 freak
I have no idea, as mentioned I have only trimmed the bare minimums, I will keep trimming as needed
OffroadAlliance.com
Boston, MA
We've still got a few sets left in stock. $1399 shipped within the lower 48 states. Give us a call and we'll get you taken care of.
Ph: 888-466-8991
Asinine
Now that my Icons on 1 have settled after 1,000 miles, I'd like to eliminate the rake. What's the best and/or suggested option -- lift up the front or lower the rear? Sitting at 43" in rear and 40.75" in front.
No plans for 37s at this time, but hey, anything is possible.
xgardx
CLE OH
All depends on what you want / are going for...
A drop shackle in the rear would be a low cost / easy install option. If you want the front to remain the same height/ rise feel.
If you want the front higher, a collar lift of 1.5” wouldn’t be bad, but the ride stiffness will increase some.
Or go with Geisers like I did. Expect a 2.5”+ lift to the front once settled. Ride is slightly stiffer (but in a good way, since the springs have a progressive rate). Wheel wells are looking a little empty now though, lol. I’m holding off the urge to fill them with 37s myself
Asinine
I've got the resi FOX's up front, so it's simply turning the adjustment collar to add height; they're already at the lowest setting. If I go that route, I'll add UCAs to address the geometry.
Jacked up the front -- looks great with the extra inch.
Added weight to the rear -- looks great without the extra inch.
I'd like a little extra height for trips to the snow, but that's a small percentage of what I drive annually. Curious what others are doing with Icons and still running 35s.
