Icon Multi-Rate Rear Leaf Spring Kit
Slow6
AK
I only have 100 miles on mine in setting two and I think what you guys are hearing is your shackles.
Are you both running stock shackles? Stock shocks?
My icons don’t make anymore noise than my deaver +2HD and they did not make any odd noise.
I have camburg stock length shackles and no noise. My brother runs stock shackles and his squeaked for the first week after install. Also take a look at your brake line on the frame.
What’s the issue/deal with the brake line?
brettmess24
The line for the e brake that runs along the side of the frame on drivers side. Has connection points running along the frame and could be slapping the bottom of the leafs as well if the insulator was moved or damaged during install.
Not the actual brake line for the calipers sorry I should have clarified;)
These. Which reminds me I need to clean up my axle:(
Cuzin Eddie
St. George, UT
I am stock shackles, but I have the Fox 3.0 adjustables. The noise is driving me CRAZY!
Cuzin Eddie
St. George, UT
I noticed that too and I made some adjustments but still there.
brettmess24
It’s probably a combo of shackles and shocks! I haven’t installed my fox factories yet but I was told to run them wide open on the street.
brettmess24
Idk brother I’ll see if I can slap them on tomorrow I’m a gluten for punishment
Viper01
FL
Yes stock shackles/shocks.
Slow6
AK
I hope it’s the stock shackles not the shocks.
