Icon Multi-Rate Rear Leaf Spring Kit
NEOGARAGE
North Royalton, Ohio
So I can go straight Icon springs in the rear and not have to get the bumps right a way ? That would save me a bunch, then I could get the Icon rears and SVC or RPG coil collars for now. Would you recommend that ?
Yes. The only other thing I’d recommend is a factory bumpstop spacer, which Icon and Camburg makes that too.
Loufish
Burbank CA
Has anyone paired the Icon leafs with extended length, (dropped shackles)? I agree the ride has been great but the forward rake is killing me? My wife calls the truck a stink bug. emoji107.png
First of all it looks like the shackle in your picture is installed backwards...and I do run a 2" longer shackle (SDHQ)with my +3 Deavers...it drops the rear height about 1" and rides better with the longer shackle...
Mkarban
Minnesota
Just take it easy :) because you won’t even have the factory bump.
Halo Raptor
Monrovia, CA
That’s what I was getting at.....no functioning bump stop.
Thats what I was getting at, is it safe when changing the spring rate to go with say the Icon factory bump strike plate replacement vs. bump stops. Unfortunately I am going to have to do the suspension in phases since I cant fork out 10k in one shot to do springs, bumps and shocks. Since it seem from everything Ive read the read leafs are the weak point, second being the very soft front shocks. If I can get Icon leafs, do the strike plate and front coil collars, its seems like it may fix some of my weekend warrior off roading problems. Thoughts on that ?
brettmess24
Yes you are on the right track!
As others have said the bump kit will be needed for serious off-road but not for mild wheeling.
NEOGARAGE
Aftermarket bump plate plus bump stop spacers for the factory bumps will do the same job and get it done. Happy to help out on getting you these things with the best deal. We've got a really good price on the springs right now plus front springs or collars depending on what you prefer. Eibach springs would help get rid of some of the plush feel in the front since their spring rate is a smidge hihger. if you PM me, I can get you set up :D
Loufish
Burbank CA
I replaced my rear springs (Deavers 3+) and that was my best single suspension mod...the new springs and the factory rear shocks work really well together...the front shocks on the other hand could use some help...
96,098
59,851
swhitt392
