I ended up going with only one middle support. I've jumped it twice since then and have put on around 5,000 miles of hammering on the bump stops with both off-road use and towing with no issues. Honestly you probably don't need the middle supports. The kit is built pretty beefy as it is.i have the same issue but run kooks dual exhaust headers back. I called icon and they were not sure if there is clearance
Yours looks like it’s similar to mine so it should work. Just have to leave the passenger side tensioner off.I was on the fence on purchasing the icon Bumstop and their leafs due to the clearance issue that I may face with magnaflow cat back exhuast ( see pic) , have the RXT 3.0 shock so I wanted everything to work in conjunction , but as you stated if it’s only the tensioners that get in the way and you can temporarily remove them until you adjust the exhuast system that will be great .
My kit is still working great!
Yep, would probably take you 20 minutes. Excluding the time it takes to drop the spareSo if I don’t install the tensioners , reworked the exhuast to make room , is it easy to remount the tensioners in the future after the work is done ?
Perfect , it’s only the tensioners that are the problem not the other parts such as the cross beamYep, would probably take you 20 minutes. Excluding the time it takes to drop the spare
