IC Shutters
2018RubyRed
Doing a little data logging, for curiosity and a comparison for when I do the cobb front mount, the shutters in front of the intercooler only seem to open under a good load (pulling long hills, no towing log yet) and when the charge temp starts getting around 120-130F area. Sometimes they will start to open in stopped traffic and open up on initial acceleration and then close back up
K223
K223
Florida
Wow that’s interesting and dissapointing at the same time. What was the ambient outdoor temperature you logged under? Can you tell if the fans engaged? If the shutters were closed most of the time, I gather they did not.
Fords strategy is obviously not geared for creating extra power, but enough. I gather it’s related to fuel economy and emissions more than anything else. Otherwise why not get that charge as cool as possibly for more power. Obviously that air temp is enough to produce maximum HP.
2018RubyRed
I did not monitor fans so I can't give you anything on that. I can't imagine them opening when the shutters are closed or when there is decent speed going on. I didn't really notice a difference with ambient temps
RaptorVette
Corpus Christi, TX
I took mine out after I installed the CVF intercooler and tune. The shutters had bug guts on them which tells me they were closed on the highway. No data to support, but the manifold temps overall are significantly lower since I removed them.
K223
K223
Florida
Based on what I’m hearing and you had big guts. It appears the shutters are closed more than they are opened. Did you leave the motor intact to avoid DTC’s? Just removed the shutters themselves?
So the before and after with the shutters was dramatic. A lot more so I take it then just the CVF added?
Oldfart
How do you know RaptorVette has a big gut? That seems a little rude!!!
RaptorVette
Corpus Christi, TX
Yes, left the motors. Just pulled the shutters out. It lowered temps another 10 degrees or so on top of the intercooler. The manifold temps are always within 20 degrees of the intake temp. Under boost the temps drop to 10 degree difference. With the shutters and CVF there was still a 30 degree or more until I got into boost.
K223
K223
Florida
Great feedback! That says a lot in regards to the new IC and shutter removal. Looks like another nice gain in reduced temps over the new IC alone. Pretty interesting.
