I installed some Fox 3.2 on my truck today and they’re awesome!
thatJeepguy
GA
I really like what the 3.0’s did to my truck with eclick on a gen2 . Must really be a huge upgrade on a 5 link truck with 37 package. Basically just need bumps and you can do some serious trail runs. Pretty cool what you can do these days with stock length uca lca.
Meat2022
Alabama
So this is on a gen 3 correct ? I didn't see what year of raptor until i.saw 2022. Or are these off of a 2022? Sorry for the stupid question just didn't see that gen 2 or gen3 reference
Ryan C
Vancouver, Canada
@slimmytimmy what setting did you run the steering wheel in? (e.g. Baja? sport?). what about the three position clicker on the coilover and shocks? Can you compare stock settings to the clicker settings on the 3.2s? On my gen 2, I remember the soft setting was softer than OEM, but the middle and firm had more damping compared to stock.
Also, did you adjust preload on the coilovers and if so, what did you set the truck at? again, on my gen 2 no preload on the ring was stock height, with a 2:1 ratio of lift:preload. I'm curious what these gen3 FRS look like there.
Thanks!!
S
slimmytimmy
Albuquerque NM
Maybe there is a different sku number than what’s on the box is 883-06-183
You might know more than me
The Fox link to them is this:
i thought 3.2 meant dual live valve.. you got 3.1s bud
S
slimmytimmy
Albuquerque NM
I only ran the shocks set to stiff.
The button definitely still works. I have a tire that is out of balance that was very noticeable on the freeway. I switched from normal to sport and it went away. That was on the same stretch of road, with the same pavement conditions, same speed.
No preload adjustment. They look squishy. That’ll all be taken care of with a couple of horizontal coil overs running the same direction of the frame. Soon…
