How wide is your ford raptor stance
banman12
Rochester, NY
Mid perch will be fine, top perch get to much harness and rebound.
But, i see most if the people here likes to keep the stock wide stance of the truck,
Actually, a lot of people are running 0mm offsets on 8.5" wide wheels, which is 34mm more "poke" than the stockers. I am leaning towards a 17x9 18mm offset. That equates to 22mm more poke than the stockers. I have seen a few run -6mm offsets. Running a 9" wide wheel wide a -12mm offset= 52mm more poke than the stock wheels, a little over 2" wider. I would say def gonna run into issues.
K
ktm505sx
What matter is the looks when you dont do offroad.
What is using rpg's truck, rsv2 from outlaw and raptizile?
RaptorScrew
Oronoco, MN
I ran the ATX -12 offset like Squatting Dog's old set up... Middle Perch and I rubbed really bad! Started ripping up my liner on driver side.
Switched over to Method Fat Fives with 0 offset.
Milez28
mine are 10" wide and offset is -12. They stick out farther than the fender well and eventhough it's on mid perch it still rubs sometimes when I pull out of my driveway in reverse and trun the wheel.. My tires are Toyo MT's 35x12.5
K
ktm505sx
Hey what about boatec fenders 37x13.5 tires 17x9 -12offset wheels, icons with UCA. Will i still rubbing the fenders?
dataustin
Initially I fit into the ATM lane at the Bank of America. Now that I have my Duratracs mounted on Method Double Standards it is a no go... :)
