how to lower tire pressure threshold so I can run lower pressure without getting a warning?
ramrodraptor
Arizona
Hi All, i'm getting a 'low tire pressure' light on my gen 3 at 30 psi.
How do I program a lower threshold (maybe 25psi) so it does not trigger a low warning light at 30 lbs ? I have forscan.
Thanks in advance !!
blwn
Florida
If you use the regular configuration in the BCM you should be able to set the PSI directly:
If you prefer to use the AsBuilt version:
BdyCM
Front: 726-10-01 - XXXX-XXXX-** (where ** is desired pressure converted to HEX)
Rear: 726-10-02 - **XX-XXXX-XX (where ** is desired pressure converted to HEX)
Oldfart
BdyCM
I had to Google what HEX was, I had never seen that before.
SurfRaptor
Newport Beach CA
This is a great question, and I'm new to this also. In my jeep, I would go down to about 13 PSI in the sand. In the raptor, I was planning on about 18 PSI for the sand with the method wheels bead grip technology. I wouldn't want to set the TPMS to 18 permanently, so is there a way to do this temporality for a trip? For example, the TPMS is disabled when switched into 4x4 or something similar?
Kind of off-topic, but what modes are you guys using for off-road. It seems as soon as I choose "off-road" mode on the dial, the RPM's are up super high but if I just put the truck into regular 4x4 high the RPM's stay on the lower side. Baja mode is a gas guzzler and seems to keep the RPM's way too high. What am I missing here. Sorry to hi-jack this if I did.
R
ramrodraptor
Arizona
hi fellas, im having a hard time finding that screen on forscan
any help would be appreciated very much.
i searched the forscan thread and I couldn't find anything there either.
it’s in the BCM ; BdyCM module config tab that’s illustrated in the picture.
6964696F74
EricM
OHIO
Do you have the extended license for the Forscan software? You need that to make any changes to the BCM.
