HOW TO: 2019+ Live Valve Recalibration - FORScan
ArizonaD54
Phoenix
Thank you forum-members!
This worked like a gem after installation of Eibach springs. Went from +30 on the fronts to 0.
As an FYI, I used Forscan version 2.3.43.
Raptor_VA
Virginia
I have a 2020 and have tried this multiple times however the VDM module never loads. I have experience with forscan, followed directions exactly, and have tried both the original version listed in the OP as well as the newest version (.44). As far as I know my truck does not have a tune but I did buy it used. Any feedback would be greatly appreciated.
most frantic
tennessee
I had a hardware issue, didnt look to deep. Tried the OBDLink LX with your same results. Switched to the EX and it worked like a champ on multiple trucks.
Raptor_VA
Virginia
My OBDLink is the one that many recommend on here that automatically switches between the modes so I would think that it should pick up the modules. Someone please correct me if that is wrong.
wazatataza
miami
Installed eibachs on my truck, it was riding like my mustang. So I went to several dealers and none knew how to do this procedure, some even called springs voiding a warranty.
Anyways this made the truck ride like new again! Supple and soft over bumps, no more clunks
TexasAggie94
Harker Heights, TX
Team, need some help. Finally got the nerve to do my ride height calibration and something is not right. The calibration process ran without error but when it was all said and done, I had 199mm in my front left right height and the rest were all zero. Tried to run it again then it failed. Ran one more time with success and had the same results of 199mm in the front left. Calibration was done on flat garage floor with a full tank. Additionally, I also now have an error message related to "Drive Control Malfunction Service Required". I did not stray from the procedures outlined in this beginning of this thread, so I am at a loss on how to get this error corrected. My main concern is to fix the error then figure out why the ride height will not zero on the front left. Malfunction.jpg
