How do glass front fenders look without liners?
BAJASVT
SE Michigan
Overall I'd highly recommend the liners and I'd pretty much say they're a requirement if you're going to wheel in wet conditions (i.e. mud). If you live in a state with snow and salt is used in the winter time, don't even think about not using liners; you DO NOT want all the salt road debris getting up into your inner fenders, firewall, engine compartment, inside the front support horns, airbox intake, etc.
CB Freshness
South Carolina
I have glassworks and they literally just sent me a sheet if material. I would go boatec. does anyone know if boatec liners would work with glassworks?
iSurvive
iSurvive
Highlands Ranch, CO
Thanks to everyone who responded. Your trucks look great with the fenders/liners.
So here are my questions:
- are the Boatec liners $300 each, or for the pair?
- what size Grabbers are those 37x?x17?
- how much offset do you need?
- can you install wheel spacers? I'd hate to replace all 6 Method Double Standards with new wheels.
- I was quoted $950 for painting just the front fenders, that seems too high?
And yes I do heavy off roading; lots of mud, snow, and river crossings.
Captain Awesome
Alberta
as far as Wheel spacer i would stay away i've seen lots of failures in the atv world. also after seeing a few guys on here break rims i don't think spacers would last long if you do any serious offloading. would rather buy new wheels then pay to fix my truck after a spacer failed.
iSurvive
iSurvive
Highlands Ranch, CO
as far as Wheel spacer i would stay away i've seen lots of failures in the tav world. also after seeing a few guys on here break rims i don't think spacers would last long if you do any serious offloading. would rather buy new wheels then pay to fix my truck after a spacer failed.
Well that answers that question! No spacers for me.
How much offset is needed?
mjyst3
Pittsburgh, PA
I was quoted:
Boatec Fenders/Liners/Shipping $1200
Install/paint $1500
Tires Toyo MT 37" $1520
Method 18" rims with offset $800
Mid Perch/Alignment $300
All this ($5320) to fit 37" MT's properly. I think I might have to pass on this mod. Although it looks badass I can't seem to justify it. Who knows, maybe I will have a change of heart after seeing your project come to fruition and reading a few more reviews. Don't mean to threadjack.
dnewman9
Lone Tree, CO.
Did your liners come with the mounting tabs or was that added by the installer? I just got my Boatecs and they did not come with them?
Do they just rest against the inside of the fender?
Thanks
Dennis
EcoRaptor13
Los angeles County Mountains
I was quoted:
Install/paint $1500
sadly, the most expensive hobby
---------- Post added at 08:01 AM ---------- Previous post was at 07:55 AM ----------
do a wrap- whole truck for $2500 instead of $1500 for just the fenders, also 18" wheels? no way no how never. stick with 17". Ford and everyone else in the offroad community chose 17 for a reason, and its the standard. more prevalent, and discounted stuff found easier. Also Ford designed suspension to run at low perch only, if i remember correctly. the other perch's are just a Fox thing, and not meant to be used for a handful of reasons. (i tried it once, a hundred years ago. bad idea) anyhow, my 2% od a dollar. just trying to help
