How about Amsoil 0W-40 Signature Fully Synthetic?
John Rathjen
John Rathjen
SWATDOC
USA
Im just thinking of cold startups where most engine wear occurs. I would think 0 wt is better there.
19Stripper
We typically have a week or two of subzero nighttime temps around here every year and a month or so in the 90s. 5w-30 is fine. Dont overthink it. Use what is recommended. Just let the truck warm up before pinning the firewall with your toes. (regardless of temp)
RC Blk Bird
Arizona
Hey guys I searched the threads on oil, but most were old.
I know the recommended oil is 5W-30 synthetic, But it seems like the Amsoil 0W-40 would be even better.
0 weight for better flow at start-up (gets down to low 30's/high 20's where I'm at), yet has the 40 wt for hotter temps (again, gets up to 115 degrees here in CA, and I do plan on towing a trailer)
Any reason this wouldn't be a better way to go?
I would recommend premium synthetics like Red Line or Royal Purple - they have API certified 5w-30 that meets Ford specs. I run Red Line in all my vehicles and have for years. Amsoil may be ok but having been involved in NHRA, AHDRA, & NASCAR racing, pretty much all the race teams I was with used Red Line.
John Rathjen
John Rathjen
SWATDOC
USA
Well this is straight from the horse's mouth:
Hello John,
Thank you for contacting AMSOIL with your question.
Ford calls for an engine oil specification of WSS-M2C946-, they also attach the spec to the oil weight. So our 0w-40 will not meet this specification that Ford calls for so a lot of times they can use that as a reason to deny warranty coverage.
I would recommend using our 0w-30 if you want to improve the cold starting capabilities, but then it will still meet the specification Ford lists because it is a 30 weight.
Let us know if you need any other information.
Thank you,
AMSOIL Technical Services
Tech Line: 715-399-8324
Email: [email protected]
