Houston we have a problem! (the bent frame thread)
DEADEYE
MN
Outstanding posts ! Very good root cause analysis.
Welcome aboard !
BlueSVT
San Dimas, CA
A short update:
The Ford Engineer is currently examining my truck at my local dealer. He is taking pictures and measurements to forward to their engineering department. Ford has already told me they are going to "take care of me" and get things right. From the sound of it, they have no issue "so far" fixing my truck, but it has yet to go through the engineers. Not sure if that will change anything, but regardless I feel good about Ford's response so far.
Will keep you all updated on the final findings, should be in the next day or two.
Bad company
You're a mechanical engineer huh? Or you take a WAY higher level math class than I did in college.........
Mechanical engineer. I designed shock isolation systems for naval electronics on the Los Angelos, Seawolf, and Virginia class submarines :patriot:. Three semesters of calculus, dynamic systems etc. etc.
We tested blast loading with high explosives in a quarry. :peace:
Raptorguy21
The Bob Vila of Trucks
Hell Paso
Damn I'm good......thats badass man, welcome to the forum by the way:waytogo:
Madcowranch
Genetically Modified
OK
Just be glad we have fully boxed frames instead of those inferior Toyota C-channel frames that FLEX.:005:
pirate air
will plunder your booty
Bad company, when you compare the kickers to jumps, is that comparing the suspension compressed cycle speed? Are the forces also equal at that point?
