Not sure if this has been fixed, but spray some pb plaster in your purge valve after you remove it and you should be good tot go! Can swap it all together for 70$Update - I am now at 175K
So far only problem has been the check engine light "check fuel fill inlet". Sometimes the truck will die at a redlight after getting gas. Other than that very pleased.
