High mileage owners please check in
SZDZMTR
Sewell, NJ
how did you just replace the boot? I have the same issue but figured I would need to get new CV
The truck was at Krazy House Customz New Brunswick NJ getting UCAs and alignment done. They pointed it out when everything was unbolted. Just new boots, repack with grease. I evidently was missing one ball bearing too, had 5 not six. It probably just fell out... luckily they had one...
Atl
This has been a great read. I'm a new owner of a '13 Screw with just over 97k miles on it. I'm taking it in this upcoming week for an oil change, will replace transmission, diff and transfer case fluids. I'm also considering doing the plugs as well either myself or at the shop.
Dumb question probably but would leaking shocks or those on their way out be easy to spot or feel while driving?
Car spent it's live just north of DC and I do see just a few small rust spots from my visual checks, anything else I should specifically ask the shop to look for? will spend time now in the south and away from the ocean.
Anything else I should ask them to check out?
Thanks everyone.
BenBB
Lots of different places
Thanks everyone.
Shocks blown or needing service aren't going to be super noticeable on the pavement, any more or less than normal shocks (i.e. jump up and down on the bumper and see if it dampens the movement or keeps bouncing); rougher terrain and they will bottom harshly and/or respond slowly but without knowing how it should feel it's not going to be obvious...best bet is to replace (rockauto) or rebuild (ideally yourself) and you'll know for sure.
Other things to have them look for: has Fuse 27 been done? Transmission lead frame? Lower control arm alignment cams maybe? The latter two aren't critical but I would definitely recommend the first and last. Undercoating and rustproofing is also always a good idea. Good luck!
Atl
Appreciate the reply.
I don't expect to do much offroading to be honest, so I may not mess w/the shocks unless there's noticeable leaking, or I do notice something off if I go out rolling in the mud somewhere w/friends.
Is there a way to tell if Fuse 27 has already been done?
What's up w/the lead frame? my Google searches have only turned up something about a 6r80 issue that was on the 2011-2012 models?
No idea what you're referring to w/regards to the LCA alignment cams, I'll get to Googling some more.
BenBB
Fuse 27: yes just look in the fuse box under the hood, the big box in the center above the radiator, and see if there's a little (usually yellow, frequently melty) fuse in the #27 location. If so, it hasn't been updated. If not, there should be a bigger, clear top blue fuse in #70, and a sticker should have been put in the fuse box lid (and in the owner's manual), and the update is done. It's cheap and easy to do, and worth not getting stranded somewhere when the engine dies or decides not to start.
Lead frame: yes I think officially only '10-'12 was affected, 6R80, read some horror stories and figured I'd rather be safe than sorry on my '13 with a 10/12 build date so next time I service the transmission I'll just replace mine. But check your build date, there's a chance it could happen to yours, just sayin'.
Alignment cams: all Gen1 (maybe Gen2 as well?) have this crappy slotted alignment system that uses slots at the lower control arm (LCA) pivots to change camber & caster. It's junk and an impact or loose nut can throw it off easily. SPC makes two different kits (be advised 2 come in a kit and you need 2 kits) that improve the system:
https://www.spcalignment.com/index.php?option=com_spc&task=part_description&pid=86250
For harder use you'd want to eliminate them entirely (KHC and Rogue have weld-in kits) and get adjustable upper control arms (UCA) to set the alignment, but that can get spendy and may be overkill.
Just my two cents though, some observations on mine over the last couple years...
Atl
So bit of good news/bad news after being in the shop today. Transfer case fluid, brake fluid, diff fluids all look to be fine. Getting the transmission fluids done as it's getting to be darker red. Rust is pretty minimal for a car that's spent 5+ yrs north of DC by the ocean, just surface stuff that shouldn't be a concern now that it's down south away from the ocean.
On the bad side, I was told the 2 front shocks are both leaking. Wondering what the best option(s) would be? A quick search turned up a company called Forged Offroad that'll do a core exchange/rebuild for about $400. Are there easier/more cost effective solutions?
Other negative is I'm told the timing cover gasket is seeping and will need to be addressed soon. Did some searching and didn't turn up much, not sure if anyone else has had this issue?
Input very much welcomed.
SZDZMTR
Sewell, NJ
Forged Offroad does great job. Give them a call and discuss your options, rebuilt with options for the money beats buying new stock shocks....
buy an bunch of AMZOIL HP metal Protector cans probably 4 clean off the undercarriage and spray the shit out of anything metal with it, prefffered if you can use a lift and let it sit for 5 6 hours before you drive the truck.
timing chain cover not so sure warranty? or get second opinion
