High beam issue
Tahoetim_42
Corona, CA
I've been having an issue with my gen 1 lately, for some reason when I hit my high beams, only one side works. I have the morimoto headlights so the low beam stays on also, but on that side the low beam turns off also. On my headlights before these, I'd hit my high beams and both lights would just turn off. When I first installed these morimotos both high beams worked, now only one side. Any ideas?
Ellison3
Arizona
Kinda makes me wonder if there is a issue from the vehicle side since the problem existed before the new headlights were installed. Possibly a short of some kind that intermittently worked upon install of new assemblies.
Irregular F150
its terrain good sir!
a small town in way up northeast
This.
After re reading it i must if missed it doing that the the before lights too
Tahoetim_42
Tahoetim_42
Corona, CA
This.
Yes, I had an issue with my high beams before installing the morimotos, I was thinking maybe it had something to do with a fuse or relay, but I looked online to try and find where the relay would be, couldn't find it.
Tahoetim_42
Tahoetim_42
Corona, CA
Indeed, at first I thought it was a fault of the headlights, but after messing with it a little and realizing it did it before, im thinking it's an issue truck side, just not sure where.
BenBB
Lots of different places
That is odd, can you check the connectors and test for voltage with a multimeter? At least find out if the truck is sending volts to the headlights; from there I would trace the wiring back to BCM (?) and then switch itself. Good luck!
