Help with Kicker sub install..
Xtinct
Nebraska
I ended up talking to kicker tech support and they were super helpful. They said I’d be better off with the vkl3t and having it turned on with forscan. With the auto start stop I would have issues installing a hideaway or aftermarket sub.
Do you have the B&O system or the Sony?
FoShizzle
Good info on the kit. FWIW I have zero issues with my aftermarket setup and auto start/stop.
B
BRaptorr
ohio
Foshizzle did you use a plug n play harness for yours? I have the 8” sync 3 touchscreen and the 7 speaker system
FoShizzle
I have the same "upgraded" B&O system from the 802A package. I just cut off the end of the OEM connector to the factory speaker and put on some RCA connectors (LINK) to the amp I added on. Heres my setup:
I didn’t know you could go this route with the b&o, but awesome. That looks almost identical to the way I had it set up before the total upgrade stage.
B
BRaptorr
ohio
Very nice! Any speaker recommendations? My last 16 f150 I installed kickers all around, but it seems they lacked output at higher volumes. I was looking into inifinity references . .
NE Raptor
Massachusetts
interesting way to do it - how do you like it? much better than factory?? i am almost to the point of upgrading
