GEN 2 Help With Heated Front Seats - Not A Fuse Problem
Basil S2K
NJ
Both heated front seats not working on my 2019 Raptor, the indicator lights work as do the heated rear seats.
Checked the fuse and It's good.
Any next steps to check before I take to the dealer (I'd really like to avoid this if it is something simple).
Thanks all
nikhsub1
Los Angeles
The heating elements have shorted out and need to be replaced... super common issue. Usually it's only the driver side due to more wear.
goblues38
STL
what he said.....here is my thread. just takes a little patiences and $27 per seat
B
Basil S2K
NJ
back again, before I tear my seats apart why would both of the seats break at almost the same time? Seems odd. Saw another you tube vid saying I should unplug everything and plug it back in, simple enough I'll do that tomorrow.
anything else come to mind?
There is just one 15 fuse for both seats that I've found and replaced, are there any others?
