I made the change, now all the lights are off while set to automatic and DRL Turned off in the advanced setting modes. One good thing that I can do now that I couldn’t do before, is, while light knob is set to “runner lights” it changed this setting back to factory, so I can run parking lights without headlights, but the turn signal lights are not on..uggWhy do you have a 726-29-02 0100 0001 005A? Change the 1 in red back to (0).
Try that and report back.
Thanks for the feedback. Are you suggesting to change it back to the original format?I have seen that 726-29-02 change cause unexplained problems for others. It doesn't apply to Raptors and the spreadsheet has misled a lot of Raptor people into changing it.
Thank you. What year do you have?Yes. I run Parking Lights and Turns as DRLs, and it works flawlessly for me. I have only edited the settings below. I have never edited 726-29-02.
It does not work on 19s and up from what I have seen
I'll check my settings for what I changed but my 19 worked just fine.
maker lights and turns only for DRL.
