Yesterday I replaced the drivers side blend door actuator. Now, when I first turn on truck, drivers side blows very hot air. I can put the temp up to 90, then hit the max cold button, then drivers side starts blowing cold like it’s supposed to. I tried pullling the #15 fuse for a couple of minutes, then putting it back, turned the key to on for a minute or so like “procedure” says to reset it, but still does the same thing.. It’s a 2010 if that matters
