Help with blend door actuator
Justimm
Yesterday I replaced the drivers side blend door actuator. Now, when I first turn on truck, drivers side blows very hot air. I can put the temp up to 90, then hit the max cold button, then drivers side starts blowing cold like it’s supposed to. I tried pullling the #15 fuse for a couple of minutes, then putting it back, turned the key to on for a minute or so like “procedure” says to reset it, but still does the same thing.. It’s a 2010 if that matters
Ruger
Northern Nevada
The passenger side blend door actuator on my 2011 is failing, so I am also interested in responses to this thread.
Justimm
Justimm
I actually went in and removed the new one, turned my ignition on, reached under there and made sure door was where I wanted it to be. I put the new one back in, then did the “calibration” and it seems to be good now
Justimm
Justimm
It’s not pretty, but what I did was pull back the carpet, remove the trim on both sides of center console, loosen screws around ac cage. I then got my handy dandy sawzall and cut the flared end off of the passenger side floor vent. I then took a crow bar and pushed down on the duct so I could pull the actuator straight out the side. No very professional, but I didn’t have to loosen dash to get it out and it took me no time to swap it out. That’s the hardest one to do.. the other 3 are fairly easy to get to
