HELP...no idea whats wrong!
Brace37
Kandahar, Afghanistan - Rogers, AR
My Raptor was fine Thursday, started fine, drove fine...and had no issues when it was parked in the garage.
This morning it would not start. Battery is fine. All the lights on the MFD come on, radio works, everything seems fine, but nothing happens when you try to start...no clicking, nothing involving the starter. Remote start doesn't do anything either. Can't take it out of park to roll it out of the garage.
Anybody got any idea what could be wrong?
swoop1156
USA
I'd have a guess if you had a 2010, but you don't, so I can't help with that idea. Good luck!
Hockster
My 45ft Bluewater Party
Winchester, Va
Push the gear shiftier towards park or put it in neutral. Could work itf it does its just needs a adjustment.
SPRSNK
I Void Warranties
Franklin, TN
It hates you. Test float it.
I really have nothing constructive to add. Failing everything else, disconnect the battery for 10 minutes the try again?
TBONE21
NC
Could be the security system messed up. It can disable the truck if it can't read the key.
