Help me break into my Console Vault...
pughde
SC
Not sure if serious...
A fob left in truck will not allow another person to open the door, at least in my one test, it is disabled. I thought it would stay disabled if using the keypad, but did not happen.
ssj4sadie
San Antonio, TX
I'm not near my Xsport manual, but IIRC...locking your vehicle with a fob inside will cause the horn to honk, letting you (and others) know you locked your key inside. That's one easy truck to steal as you walk away.
pughde
SC
Did not see that with Raptor. My wife left her purse in the car with a FOB in it. I was concern someone could break in and start the truck. The door would not open automatically with FOB inside if person outside did not have a FOB. I guess using the keypad allows FOB inside to become active.
JetDriver480
Question... I often lock my key in my truck at work incase it needs to be moved while I am gone and simply use my own side keypad on the door to gain access to my truck. Does this work in the new Trucks?
This way if they need to move the truck (rare) I can just give them the code.
JetDriver480
^ Even better. Thanks!
Question.... I do park under-ground. Will this still work? Ford Pass is cellular or?
