If your buying a jack for your raptor, for your garage and have an air compressor this works great https://www.harborfreight.com/20-ton-air-over-hydraulic-jack-95553.html
The air over option makes the whole thing a breeze. You get plenty of height, and capacity.
I use a Pro Eagle 3 ton floor jack performing any works on the truck and also carry it on my truck when I'm on a trip.
You will want this:
https://www.harborfreight.com/3-ton-low-profile-super-duty-rapid-pump-floor-jack-yellow-63183.html
I don't know the numbers off the top of my head, but any standard jack is not going to lift this truck without additional helpers, which may or may not be dangerous. Best to go with one that is high lift. This one will raise just enough to do a tire rotation.
Lifting the rear on the pumpkin, which will be a debate as well, allows for a standard jack to work though, it's the front that is a PITA.
